Activity Forums Apple Final Cut Pro Legacy Audio sampling
  • Posted by Antoine Vermeesch on March 22, 2012 at 10:13 am
    Does anyone know why the audio sampling and TC is linked with the sequence preset (not sequence settings) of FCP?
    I had some strange out of sync problems on my last projects, the audio that I import take over the sampling of the frame rate sequence preset,…
    For example, I receive a wav file 48khz 30s long based on a edit @25fps.
    All my sequence settings are fine and coherent but when I import this audio file FCP told me
    that it was not 30s long but 29s23fr,… (my sequence preset was on 23.98 fps
    BUT if the sequence preset is 25fps, and i import the same file it’s suddenly correct and 30s long,…
    ….. Why?
    Tx
    Antoine
    Antoine Vermeesch replied 14 years, 5 months ago 2 Members · 2 Replies
  • Nathan Chesney
    March 24, 2012 at 9:33 pm
    I’ve had similar issues with my audio tracks. I found that in the EASY SETUP menu you choose what frame rate you want use for your sequences. Since FCP reads in timecode it has to turn seconds into frames. It takes the .wav file and timecodes it to whatever frame rate you have in your EASY SETUP.
    Someone correct me if I’m wrong.
  • Antoine Vermeesch
    March 26, 2012 at 6:49 am
    Thanks Nathan,
    I find out this response also,..
    https://brucesharpe.blogspot.com/2010/02/dslr-sync-drift-in-final-cut-pro.html
    Tx
