Audio Renders look fine, repeat– read on…
Recently I’ve begun seeing a weird audio error, especially on clips that I relink or are from a Media Managed project. The audio clip will start right, then at some random time start over from the beginning. Associated video doesn’t repeat, and if I match frame to the master clip it seems to be fine and I can recut it in to fix the error. However, it means that when I make minor changes to a show I have to recheck all audio for the problem.
Anyone else running into this weirdness? Love to hear from you.
MediaWorks, Inc.
Your Image is Our Mission; ‘On Target’ is Our Mantra; Satisfaction is Our Manifesto
