Activity › Forums › VEGAS Pro › Audio related isssue
  • Audio related isssue
    Posted by Adan david on September 4, 2026 at 12:54 pm
    Hey guys, when I’m cutting out some parts from a dialogue, is it better to use audio transition or manually cross two audio tracks?
    I can’t find the answer for this issue anywhere.
    Silviu Negoita
    replied 3 weeks, 4 days ago
    2 Members · 1 Reply
  • Silviu Negoita
    September 4, 2026 at 2:59 pm
    For dialogue edits, I’d usually use a very short crossfade between the two audio clips rather than an audio transition preset. It helps smooth out the cut and avoid clicks or abrupt changes in background noise.If the dialogue and background sound match well, you can keep the crossfade very short. If not, you may need to adjust the clips manually or add some room tone underneath.This video might also be helpful: https://www.youtube.com/results?search_query=VEGAS+Pro+audio+crossfade+tutorial
