Activity Forums VEGAS Pro audio question…
  • audio question…
    Posted by Jerry Neal on October 25, 2007 at 8:00 pm
    Hello,
    When shooting weddings, I usually have my shotgun mic on my right channel and a direct feed from the audio board (music, speeches, etc.) on the left channel of my camera. When I edit this onto DVD, should I combine these tracks or leave them as is (seperate right and left)? My only concern if I leave them is that they won’t play properly on an older (mono) TV and only one audio track would be heard. Any advice regarding proper audio settings would be greatly appreciated.
    Edward Troxel replied 18 years, 11 months ago 4 Members · 4 Replies
  • Edward Troxel
    October 25, 2007 at 8:24 pm
    Duplicate the audio onto a second track. Set one of the tracks to “Left Only” and the other to “Right Only”. This will cause that one side to go out BOTH channels but will also let you control the volume of each individually.
    To make things really easy, download a “Stereo Split” script which can do all of the above for you at the touch of a button.
    Edward Troxel
    JETDV Scripts
  • Rick Mac
    October 26, 2007 at 3:13 am
    [Raiderneal] “When shooting weddings, I usually have my shotgun mic on my right channel and a direct feed from the audio board (music, speeches, etc.) on the left channel of my camera. When I edit this onto DVD, should I combine these tracks or leave them as is (seperate right and left)?”
    You should as Edward suggested mix the two sources to mono.
    An easy way to split your stereo track to two seperate
    mono tracks for mixing is to use a script.
    Here is the link to a free one.
    You must first register on this site. It is free
    and there is a wealth of other free scripts and great
    tutorials in the newsletter section.
    https://www.jetdv.com/vegas/forum/viewtopic.php?t=857
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Joe Gaziv
    October 28, 2007 at 11:06 pm
    [jeditdv] “This will cause that one side to go out BOTH”
    Can you clarify that, how that way one side go out on both tracks ?
  • Edward Troxel
    October 29, 2007 at 2:26 pm
    When you choose “Channels – Left Only” – that will take the LEFT channel and output it out BOTH stereo outputs.
    Edward Troxel
    JETDV Scripts
