Activity › Forums › VEGAS Pro › Audio Production
  • Audio Production
    Posted by Gabriel Villar on June 3, 2018 at 5:45 am
    What are the best specs to build a PC for audio production in Vegas?
    I normally work with it for animated movies but it has happened that when starting to add third party VSTs the computer or Vegas will crash. Just after the 9th VST and the program starts to have problems to keep up. Or even the session willl be unusable and will have to go from a previous one.
    If anyone has made something more than editing and rendering video but specially audio, like sound design and/or music, would be of much help!
    Thanks.
    Sean Dre replied 8 years, 3 months ago 2 Members · 1 Reply
  • Sean Dre
    June 14, 2018 at 10:18 pm
    Hey there,
    i have 14 years if experience with music production and audio design. I recommend you to use a different program for audio purposes such as cubase.
    but it sounds like your system has not enough RAM. For Audio production you will need at least 8gb Ram. One of my first systems was like that
    CPU. Intel i5 3750k
    GPU Build in From Mainboard
    8GB Ram
    Audio Interface Focusrite Safire USB6
    I was able to do audio mixes with more than 80 audio tracks in a project. And produce music with about 20 VSTi’s.
    But it always depends on the vsti you are using. A nexus2 or eletrax won’t need that much RAM like an Kontakt Library.
    So when your PC or the program crushes at a specific amount of VSTis I think it’s a RAM problem. But check your CPU as well. If its similar to the i5 3570k you should be good and get more RAM. but always check that you are using the 64bit version of the program and windows. otherwise the program won’t use more than 4gb ram no matter how much ram u got. So get the 64bit versions and 8-16 GB RAM.
    Check the Audio Buffer Length. When the sound starts to crack it means your CPU is to slow. u can bypass that with increasing the audio buffer length.
    Cheers
    Sean
