Activity Forums Adobe After Effects Audio problems – Pulsing or skipping when render
  • Audio problems – Pulsing or skipping when render
    Posted by Rsgalloway on December 11, 2005 at 8:07 am
    I am having a problem with audio that I just can’t figure out.
    Ok, I import some quicktime movie clips, then add a mp3 audio track.
    When I run an audio preview, everything is fine, but when I “Make Movie” I get a regular pulsing or hiccup in the audio track every time. Doesn’t matter what settings I use, it’s always there. Again, preview is fine, just with renders.
    I am using 6.5 but it was the same problem in 5.0. Thanks for any help.
    Michael Szalapski replied 20 years, 9 months ago 4 Members · 3 Replies
  • Don Sciore
    December 11, 2005 at 5:49 pm
    AE still doesn’t play well with mp3.
    Try converting your audio to wav or aiff and then re-rendering.
    Good luck.
  • Enzo Tedeschi
    December 11, 2005 at 9:27 pm
    Convert your mp3 to a .wav file and use that. You’ll get better results.
    e.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Michael Szalapski
    December 12, 2005 at 9:27 pm
    What those two ^ said about not using mp3…
    and
    The Render Queue is a much better way (more options) to get video out of AE.
    The “Great” stands for “Not-So-Great”
