Activity Forums Apple Final Cut Pro Legacy Audio problems after compression
  • Audio problems after compression
    Posted by Wil Magness on November 8, 2010 at 6:53 pm
    I am not sure if the problem is in Compressor or FCP.
    First, using “Send to Compressor” I compressed a 1 hour sequence using the “DVD 90 Minutes Best Quality” settings creating an MPEG and a Dolby Digital file.
    The video came out fine, but about half way through the final sound file, the audio cuts out and there is complete silence for the rest of the file. I retried compressing a few times and got the same result with slight variations.
    I went through the FCP sequence and replaced a number of MP3 files with AIFs because I read that the embedded compression could cause problems but this did not fix it.
    I then exported the sound as an AIF from FCP and, using Compressor, tried to create the Dolby Digital file again. This time all of the audio is there, but around the same place there is a very loud crunchy/static/beeping sound that lasts about 30 seconds. The rest of the audio is fine.
    The sequence I am working in has many audio tracks due to the fact that we overdubbed most of the movie and inserted tone and sound effects. Most of the files are AIFs, but some of them are WAVs. Could this be the problem?
    Going through the whole movie and converting all of the files to AIFs and replacing them would be a huge project, so I’m not eager to do that. If anyone has any idea what may be causing this, I would be very interested.
    I am using:
    FCP 7
    Compressor 3.5
    On a 15″ MacBook Pro
    Wil Magness replied 15 years, 9 months ago 2 Members · 2 Replies
  • Chris Borjis
    November 8, 2010 at 10:04 pm
    maybe try deleting all the audio renderings in the project folder, then
    export again as an .aiff
  • Wil Magness
    November 9, 2010 at 8:38 pm
    Sorry, I miswrote originally. I replaced all of the mp3s. I meant to ask if I should do the same with .wav files or if they\’re okay.
    In any event, I believe I\’ve resolved this situation. My sequence was set to 48 kHz while most of my audio was 44.1 kHz. I switched the sequence setting, rendered again and it appears to be fine.
    I still have some random 48 kHz audio clips in the sequence, but there is no noticeable distortion (yet, I haven\’t watched the full DVD)
    I read in the fcp manual that it was better to have 44.1 kHz audio in a 48 kHz sequence than the opposite, but could it be that that only applies when the majority is 48 kHz? I definitely have a majority of 44.1 kHz.
    At any rate, thanks for your help! These forums are great!
