Activity › Forums › Apple Final Cut Pro Legacy › audio problems!!!!
audio problems!!!!
Posted by Peter Brusikiewicz on March 14, 2006 at 10:17 pmOkay so here is the problem that I am having
Kevin Monahan replied 20 years, 6 months ago 3 Members · 2 Replies -
Debe
March 14, 2006 at 11:51 pmSelect your sequence with the 44.1 track in it.
Hit CMD+0 (zero)
Change the audio sample rate to 44.1.
You should no longer have to render.
You shouldn’t have distortion problems unless there’s something more going on that hasn’t been addressed.
debe
Kevin Monahan
March 15, 2006 at 7:48 pm
