Activity › Forums › Apple Final Cut Pro Legacy › Audio Problems
  • Posted by Bradley Kipe on November 4, 2005 at 3:23 pm
    I’m sure this question has been answered before but after searching through most of the forum I couldn’t find it. I’m having problems when capturing from our Sony DV Deck into FCP. After I capture the footage I’ll play it back and the audio has slipped. So I always have to move the audio around when in the timeline. Any help will be most appreciated. Thanks.
    Bradley Kipe replied 20 years, 10 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    November 4, 2005 at 3:33 pm
    1. If you are using external FW drives, they are not “sanctioned” by Apple for use with FCP. They may not be able to “keep pace” on longer clips. Use internal drives (but NOT the drive that contains the FCP software).
    2. You should capture in clips of 10 minutes or less.
    If you “off-line” and mark the in-points and out-points on “good” takes and capture them, it may help.
    On “long-form” programs (music, plays, lectures. etc.) you can mark the long takes into under-10 minute clips and recombine them on the timeline.
  • Bradley Kipe
    November 4, 2005 at 5:00 pm
    Thanks for the help.
