Activity › Forums › Adobe After Effects › Audio problem with Timewarp effect
  • Audio problem with Timewarp effect
    Posted by Seanmarklamblewis on July 8, 2007 at 7:11 pm
    I learned how to use time remapping and I had no problem with the audio staying synchronized with the speed changes in video but, I like the effect of timewarp better so I’m experimenting with it.
    The main problem I come across is that after I add the desired keyframes with the speed changes, I RAM preview the composition and the audio is the original, unchanged audio I began with. The audio doesn’t warp like the video does. I exported the comp to double check and still, I had a problem.
    Does anyone have any idea how I can use the Timewarp effect and have the audio change according to my keyframed speed changes?
    Peter Litwinowicz replied 19 years, 2 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    July 9, 2007 at 6:53 pm
    If I recall correctly, Timewarp doesn’t work with audio. Have a quick look at AE’s Help Menu-> Effects Help and jump to the Effects->Time->Timewarp.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Peter Litwinowicz
    July 9, 2007 at 8:00 pm
    I know you are not asking for a product placement here :-), but Twixtor can work with Time Remapping in a way that also time-remaps the audio appropriately using AE’s audio time-remapping while using Twitor to time remap the frames. FYI, You’ll need a workaround that involves precomping (see our manual and sample project files that are available).
    Cheers,
    Pete Litwinowicz
    https://www.revisionfx.com/products/twixtor/
