Activity Forums Apple Final Cut Pro Legacy Audio Problem Importing DV25 QT into FCP4.5
  • Audio Problem Importing DV25 QT into FCP4.5
    Posted by John Harper on March 24, 2010 at 3:47 pm
    When importing a QT with DV25 codec and 2 channels of audio 16Bit 48k Big Endian – FCP will only import one mono audio track.
    Have checked project settings, audio settings etc – any ideas?
    John Fishback
    replied 16 years, 5 months ago
    2 Members · 3 Replies
  • John Fishback
    March 24, 2010 at 5:18 pm
    If you are Capturing, make sure both audio tracks are turned on in the Clip Settings tab in Log & Capture. If this happens when you Import, are you sure the clip actually has 2 channels? Where are you seeing only 1 channel?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • John Harper
    March 24, 2010 at 6:50 pm
    The QT is an import, not a direct capture.
    QT’s captured onto another mac from beta deck via sdi with 2 channels which are visible when playing back in QT player.
    Then imported into a DV PAL project in FCP where only one mono track appears.
    Will provide any more info if it helps diagnose problem.
    Many Thanks.
  • John Fishback
    March 24, 2010 at 8:46 pm
    When you double-click a clip in the browser and it opens in the viewer, do you see two mono audio tracks shown (A1, A2) or a single stereo audio track?
    Have you trashed prefs and repaired permissions? If not, try that. It’s the first action I take when FCP gets strange.
    John
