Activity Forums Adobe Premiere Pro Audio Problem
  • Audio Problem
    Posted by Jeff Anderson on June 5, 2005 at 11:29 pm
    I need help with a wierd audio problem with Premiere 1.5 during playback and export to tape. Audio will occasionally drop 10 to 15db and then return to normal level while playing back the timeline for no apparent reason. When the audio level drops it happens while going clip to clip. I have some processing going in the clips (limiter & compressor) but that should not cause an issue. I don’t think the problem is disk speed since I have no video frames being dropped.
    This problem happens to me while exporting to tape a 30 minute show. The audio is fine until about 12 minutes into the program and then it will drop for about 3 seconds and then return to normal. If I stop the export and go back to the timeline I can play the same few clips where I heard the drop in level and it sounds fine. The problem seems to develop over a period of time but is not always consistant. I can export to tape again and the audio will drop during a different time. Any ideas?
    System Specs . . .
    MB – Supermicro P4SCT+II
    CPU – P4 3.4
    RAM – 2GB
    OS – Win XP SP2
    Video – Matrox Parhelia with dual LCD monitors
    Boot HDD – WD 7200 RPM
    Video array – Stripe set of 4 x 250 GB SATA HDD with Promise FastTrak S150 SX4 RAID controller
    Video Capture – Decklink Extreme v4.8.1
    Video Editor – Adobe Premiere v1.5
    Jeff Anderson
    Mike Velte replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mike Velte
    June 6, 2005 at 11:41 am
    Even with your impressive hard drive arrangement, you problem may be due to poor playback of audio preview files. This can be due to these files residing on the same disc as video files. Short term workaround would be to export a .wav file of you entire timeline. Export that file to a disc other than the one that has source video or video preview files. Put this wave file on your timleine and turn off original audio tracks.
