Activity › Forums › Apple Final Cut Pro Legacy › Audio Problem
  • Posted by Jon Spells on May 19, 2010 at 1:35 pm
    I started making music video dvd’s and the problem I just ran into is that when i add a new music video to the timeline i have to add it to a new track. Example if the last video was on V2 and A3,A4 and i want to mix the audio together then i have to add the new video to V3, A5,A6. I was about half way through the project when this started happening. I was using just V2 and V3 but now im getting up V6.
    I must have done something because this is not my first dvd that i made.
    Just to clarify to you if i have an audio track on A5/6 and want a new audio file then it has to be added on A7/8 in order to have both audio files playing at the same time. If I add it to A3/4 i will not play until the end of the track thats playing on A5/6.
    I hope you guys can help me.
    Thankx in advance.
    Jon Jon
    Jon Spells replied 16 years, 4 months ago 2 Members · 2 Replies
  • Michael Gissing
    May 19, 2010 at 11:43 pm
    The behavior you describe doesn’t sound right if you are doing this in Final Cut Pro.So I am guessing that you are trying to edit in DVDSP.
    With so little information I can only advise you to edit in FCP and then make your DVD.
  • Jon Spells
    May 20, 2010 at 2:44 am
    Sorry. I am using final cut pro 7. And like I said I was about 8 songs in when this started happening. If I have to keep and songs to new track the what is the maximum number supported in fcp?
    Thanks for the quick reply and sorry for mis-info.
