Activity › Forums › Apple Final Cut Pro › Audio Pops When Chopping Clips
  • Audio Pops When Chopping Clips
    Posted by Dustin Croniser on April 3, 2018 at 7:15 pm
    So I haven’t had any luck finding this online.
    So, I edit VLOG’s and there’s a lot of dialogue to chop up. Tons of splicing between sentences, so theres often a pop in between the clips, where one audio ends and another begins.
    My current process is chop clip, fade audio by 1-2 on each side, then repeat. Incredibly tedious and time consuming. It seems like theres gotta be a simple solution to just edit the video, select all the clips and then apply audio fades to everything.
    Anyone have a simple solution for this? You will make my editing life SO MUCH HAPPIER!
    Thank you!
    Dustin Croniser replied 8 years, 6 months ago 2 Members · 2 Replies
  • Joe Marler
    April 3, 2018 at 8:27 pm
    An audio pop is common when cutting audio and the levels are mis-matched on either side of the cut. The typical solution is add a small fade to either side.
    In FCPX 10.3 and later this can be done with a single keystroke for a batch of clips. The duration of the audio fade is adjusted in FCPX preferences>Editing>Default Fade Duration.
    The menu to apply them is Modify>Adjust Volume>Apply Fades.
    By default there is no shortcut key assigned but you can easily do this as shown in MacBreak Studio #387:
    https://www.youtube.com/watch?v=c-NQeBleOWo
  • Dustin Croniser
    April 3, 2018 at 11:03 pm
    Dude your awesome! Thank you, this is such a huge help!
