Activity Forums Adobe Premiere Pro audio popping on video capture
  • audio popping on video capture
    Posted by Chris Craig on April 12, 2016 at 9:36 am
    Hi all
    I have 2 Mac computers. Each with the latest versions of premier pro. Im capturing video8 from a camera using firewire.
    This morning when i began my video8 capture, the audio has a constant popping noise. I have tried a number of things from restarting, trashing the prefs, trying different hard drives to capture too and nothing has worked. I have also tried my second machine and the same thing is occuring.
    Monitoring the audio from the camera and the sound is fine. Its in the transfer or so i thought.
    I then used a different capture program called Vidi and this has managed to successfully capture the video and audio with no problems.
    Can anyone shine a light on what could have messed up premiere pro as it has been isolated to that.
    Thanks a lot
    Jeff Pulera replied 10 years, 5 months ago 2 Members · 1 Reply
  • Jeff Pulera
    April 12, 2016 at 1:39 pm
    Most MiniDV and D8 camcorders will record 16-bit 48k audio by default, but a few may offer 12-bit 32k audio recording. Make sure the capture spec matches what is on the tape or it can cause strange issues.
    Jeff Pulera
    Safe Harbor Computers
