Activity › Forums › Apple Final Cut Pro Legacy › Audio Pop filter
  • Audio Pop filter
    Posted by Greg Ball on October 30, 2006 at 6:19 pm
    I’ve tried to add an audio pop filter to the voice track I’m working on, When I render it, the voice disappears, although the audio waveforms are still there. What am I doing wrong? Thanks
    Greg Ball replied 19 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    October 30, 2006 at 8:34 pm
    What format is the voice in? If it’s mp3, convert that using compressor to 48k 16bit or above and then edit. FCP does not do well with mp3s.
    Jeremy
  • Greg Ball
    October 30, 2006 at 9:36 pm
    It’s an aiff file. Thanks
  • Greg Ball
  • Bouncing Account needs new email address
    October 30, 2006 at 10:46 pm
    What kind of “pop filter” are you using?
  • Greg Ball
    October 31, 2006 at 1:29 am
    pop filter in FCP 5.1 audio effects/filters
  • Jeremy Garchow
    October 31, 2006 at 2:39 am
    You should move out to Soundtrack Pro and try getting rid of clicks and pops there.
    Jeremy
  • Greg Ball
    October 31, 2006 at 3:21 pm
    I would think there would bbe someone here that can give a simple answer to what must be a simple problem.
    There is a voiceover recorded where the executive was popping his P’s. It appears that FCP has a filter that minimizes these pops. Does it not work? ALL I’M TRYNG TO DO is apply that filter to the track in the timeline. When I do, it shows me that I need to render it. When I render it, the audio disappears, yet the audio waveforms are still there. WHAT AM I DOING WRONG?
    Thanks.
