This can happen anytime you go from one clip to another with an audio cut. Even a two-frame audio dissolve between clips can eliminate the click. The reason for the click is the cut doesn’t happen where the audio waveform crosses zero. There is an instantaneous jump from one level to another which can cause the click.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
