Activity Forums VEGAS Pro Audio Playback Stutters
  • Audio Playback Stutters
    Posted by Tyson Onaga on October 17, 2014 at 3:14 pm
    Having a weird problem with Vegas 10.e.
    Insert an event a.wav; playback stutters. Vegas plays a fraction of a second and skips.
    Delete event a.wav; insert event b.wav; playback stutters. And, portions of a.wav also play. There is NO event a.wav on the timeline.
    a.wav and b.wav play fine in other media players.
    Have already used Options.Preferences.Audio and Audio Devices, reset defaults.
    Anyone else seen this?
    John Rofrano replied 11 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    October 19, 2014 at 1:32 pm
    What sample rate and bit depth do the problem wav files use? Video projects should be using 48K/16-bit. Perhaps the wavs don’t match this are Vegas Pro is converting them on-the-fly which is causing them to stutter. (just a guess)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tyson Onaga
    October 20, 2014 at 6:26 pm
    Thanks for the reply John.
    They are standard .wav files, 16-bit stereo 44.1 KHz
    This is the truly weird scenario:
    a. Insert Event A.wav; PB stutters
    b. Add B.wav to Media Pool
    c. Delete Event A.wav
    d. Insert Event B.wav
    e. Delete A.wav from Media Pool
    PB stutters w/ fragments of B.wav AND A.wav
    A.wav isn’t even in the project.
  • John Rofrano
    October 21, 2014 at 4:11 am
    I agree it’s odd. I would report it to Sony and send them the wav files since it’s obviously something with that particular file.
    ~jr
