Activity Forums Avid Media Composer audio playback rate
  • audio playback rate
    Posted by Shashank Walia on July 7, 2007 at 2:03 pm
    he can anyone please tell me how to control audio playback rate of an audio track and also which is the best setting used in sorenso squeese for high quality dvd output……….
    help will be appreciated
    thanks
    Rhewitt replied 19 years, 2 months ago 2 Members · 1 Reply
  • Rhewitt
    July 8, 2007 at 10:38 pm
    For Squeeze,
    The best setting for greatest quality/compatability with DVD players is the MPEG2 DVD_PAL-Lg or DVD_NTSC_lg depending on your format.
    By audio playback rate, I’m assuming you mean the sample rate. The audio sample rate for DVD is 48KHz.
    Depending on your capture source it is usually best to use 48KHz audio throughout if your destination source is DVD.
    In most Avid editing applications you set your project to match your source. eg. DV25 – DV Video/48KHz 2-channel audio. You also have the option to automatically up-sample any other imported audio media into your project.
