Activity › Forums › AJA Video Systems › audio playback problems
  • audio playback problems
    Posted by Maurice Jansen on March 29, 2011 at 7:01 pm
    hi there
    i have rented a kipro to investigate if it would be a good investment for our company.
    the recording part is great but i have some question’s about playback.
    for some reason the audio is acting strange when i hit play.
    i get the first frame’s of audio then a silence of a few frames and then it is running normally. is this a bug. am i doing something wrong.
    when we buy them they will be used in a genlocked enviroment on SDI
    grt
    Maurice
    People saying they don’t make mistake’s often make nothing at all!
    Rodrigo Allendes-fernandez replied 15 years, 2 months ago 2 Members · 1 Reply
  • Rodrigo Allendes-fernandez
    July 26, 2011 at 5:05 am
    Maurice, can you give us more info about the issue? Version of the firmware?
    I have some questions.
    Which inputs of Video and Audio are using you? Any in-conversion? Normal or psf record? Playback as normal or progresive? Do you are monitoring audio with SDI or HDMI, or XLR/RCA outputs? Directly to a monitor or to a attached converter? Have you monitoring audio trought headphones output? You issue is reflected by the VU meters? The issue appears at start of all clips or just one? Is the same in Loop+One mode?
    Do you review the file into a Mac or in a FinalCut?
    Let us know for a better diagnose.
    Best Regards.
    Rodrigo Allendes-Fernandez
    Video Assist Operator
