Activity Forums Apple Final Cut Pro Audio Playback Problems
  • Audio Playback Problems
    Posted by Ken Bennett on February 25, 2023 at 8:23 pm
    Running FCPX 10.6.5 on a Mac Studio running Ventura 13.2.1
    One camera shoot, one audio source (wireless lav)
    During editing and playback the audio often drops out and lags behind (out-of-snc). All random. Starting and stopping playback help a little but not much. Audio waveform is present. What could be the issues causing this. Possible solutions.
    This audio issue is new. Hasn’t happened in the past.
    THANKS for you feedback.
    Ben Balser replied 3 years, 5 months ago 3 Members · 6 Replies
  • Ben Balser
    February 25, 2023 at 8:52 pm
    What is the format and sample rate of the audio?
    What is the format of the video?
    What “percentage” of your system drive is free space?
  • Ken Bennett
    February 25, 2023 at 9:33 pm
    Video format is 4K MOV audio probably 44.1khz. Many came just stated ALC. Same formate I’ve used for the past 6 years. On the system drive I have about 25% free space.
  • Ken Bennett
    February 25, 2023 at 9:46 pm
    The actually audio recording is 48kHz/16bit
  • Doug Metz
    February 26, 2023 at 11:14 pm
    Any filters or effects on the video or audio? Some plugins (even a few of the built-in ones) carry a heavy processing penalty and could cause something like this. If so, you could try to disable those on the timeline clips to see if playback improves.
  • Ken Bennett
    February 27, 2023 at 12:11 am
    I’m lead to believe this is the case. I’m using a 3rd partly plug-in Luca VisualFX Image Sharpener along with a vignette. Turning them off does help a bit. On the audio I’m using CrumplePop Denoiser and Compressor.
  • Ben Balser
    March 9, 2023 at 6:44 pm
    I use CrumplePop audio plugins, and never had any playback issues on any of the Macs in the TV station I ran production for.
