Activity › Forums › Apple Final Cut Pro Legacy › Audio Pan setting is -1 on imported clips
Jeremy Garchow replied 16 years, 1 month ago 3 Members · 21 Replies
Jeremy Garchow
August 5, 2010 at 4:58 pm[Nary Von] “When capturing I use Final Cut’s “Log and Transfer” utility. How can I choose to bring the clips in as dual mono? “
First of all, what format is your footage?
Second, you want this:
Not this:
[Nary Von] “After searching the internet and playing with Final Cut for awhile, I’m not sure how to unpair an exsisting audio clip and make it dual mono.”
Select the audio, hit option-L, then hit control-period. This will make them dual mono then pan them to center. you can do this with multiple selected clips.
