Activity Forums AJA Video Systems Audio output question
  • Audio output question
    Posted by Logan Kelsey on December 13, 2005 at 6:38 am
    I’m just getting around to setting up my new Kona LH (new user) and I’m having a bit of an audio problem on playback. I’m getting a bit of an echo (for lack of a better term) at the end of any audio clip playing in FCP, or any audio file (QT – etc..) playing through the CPU’s audio out to the Kona board.
    KL-Box
    No audio mixer.
    +24 dBu FSD in control panel
    2.0 G5
    1.1.6 drivers
    QT 7.0.3
    TIA
    Cheers,
    Logan Kelsey
    Vertical Online
    https://www.verticalonline.com
    Jeremy Garchow replied 20 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    December 13, 2005 at 9:31 pm
    This is from the Kona 2 support page, but I bet it applies for your Kona Lh as well. It is not recommended to use your Kona for your system audio output.
    https://www.aja.com/pdfs/KONA2_Audio_FAQ.pdf
    If you have a mixer, simply take the audio out of the headphone jack of the G5 and run into your audio monitors, leave the Kona for FCP.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.03 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Logan Kelsey
    December 13, 2005 at 10:12 pm
    [JeremyG] “This is from the Kona 2 support page, but I bet it applies for your Kona Lh as well. It is not recommended to use your Kona for your system audio output.
    ” target=”_blank”>https://www.aja.com/pdfs/KONA2_Audio_FAQ.pdf”
    From the PDF:
    “Choose
  • Jeremy Garchow
    December 13, 2005 at 10:20 pm
    No problem. Please be aware, if you use your Kona for audio monitoring with anything but FCP and you change your output levels with the volume up down keys on your keyboard, you will have to reset this control panel as the levels will change. That is why I do not recommended it for use with your system sounds.
    Jeremy
