Activity Forums Apple Final Cut Pro Legacy Audio out of sync – weird
  • Audio out of sync – weird
    Posted by Pedro De la fuente on July 30, 2008 at 10:18 am
    Hi Guys, this might be an easy one but I can’t figure it out. I am working in a DV PaL sequence at 25fps, everything was running smooth till I opened a file on Quicktime (outside FCP), the file crashed the quicktime software but not the FCP, which I did quit anyway. Then is when the problem happened, I opened FCP again and had no audio, went to the AUDIO VIDEO Settings menu and weirdly my audio output was set to DV Firewire (which I dont use). I’ve put it back to Built in audio (tested the other ones as well) and I have audio now but is slightly out of sync. I believe it could be something related to the processing of audio but I played with the settings (tried to lower the quality of audio and video) but no success. I ve exported a test and the exported video is synced which makes me even more puzzled.
    Tks in advance for your time and expertise.
    All the Best,
    Pedro
    Pedro De la fuente replied 18 years, 1 month ago 2 Members · 2 Replies
  • Rafael Amador
    July 31, 2008 at 5:21 am
    Hi Pedro,
    Have a look to System Setting> Playback Control> Frame Offset.
    Set it to “0” and have a try.
    rafael
    http://www.nagavideo.com
  • Pedro De la fuente
    August 1, 2008 at 3:32 pm
    Tks dude. it did work. DUnno how it could have changed on its own.
    Much appreciated.
    Take care
