Activity Forums VEGAS Pro Audio out of sync in Vegas 6
  • Audio out of sync in Vegas 6
    Posted by Zanoaga on January 4, 2007 at 1:02 am
    What am I doing wrong? When I open an MPEG file (between 3-10 minutes long) in Vegas 6 the playback is OK. But when I render the file the sound goes gradually out of sync. First minute is OK but as it progresses I can see it’s out of sync. Need to mention that the video is some kind of speech or a presentation that was recorded on camcorder and captured in hard drive (not in C: drive). The original video is OK – nothing out of sync (even if is 1 hour long)the only trouble I have is after I render it with Vegas even with no editing at all, no effects sometimes with the addition of an “title” with medis generator.
    My system is pretty strong: CPU Intel P4 2.8 running on 800 MHz bus Hyper-Threading 1GB memory and 2 dedicated hard drives for video storage- one is Firewire (where goes the rendered file)
    Could someone help me? Thank you
    Don Bloom replied 19 years, 8 months ago 2 Members · 3 Replies
  • Don Bloom
    January 4, 2007 at 11:51 am
    This has happened to me a couple of times and trust me I pulled what little hair I have out searching for a reason it happened and found absolutely no reason at all that this should have happened. Anyway here’s what I’ve done the 2 times it’s happened to me to fix it. I delete the MPEG and re-render the Vegas project. Sounds like a real PITA I know but it worked both times AND by the time you putz around trying to find an answer you could have re-rendered it 4 or 5 times because I don’t think ther is an answer except to say COMPUTERS and WOMEN! You can’t live with them, you can’t live without them! Well you could but how would you check your EMail and who would do your laundry ;-O (my wife has NEVER done my laundry-but she keeps me for other purposes)
    Anyway I digress-it’s early A.M. so, re-render the job and you should be OK it’s just something that happens once in a while.
    I know that doesn’t help but it’s all I got! ;-()
    Don
  • Zanoaga
    January 4, 2007 at 7:15 pm
    Thank you Don for your imput. Very strange indeed..I wonder if the creators of Vegas have an explanation. It’s kind of frustrating though. The software is not cheap so I hope it will not come down as a waste of money. Frankly I really like Vegas for the features…but I need it to bring back results.
    Anyway I will follow your advice, first cause I know now that you’re doing your own laundry.
    Thanks again,
    Zanoaga
    PS. Sure you noticed I didn’t ask what’s the purpose your wife keeps you!
  • Don Bloom
    January 4, 2007 at 8:09 pm
    I cook and clean 😉
    As for being a waste of money as I said this has only happened to me 2 times an once I DID do something different than normal (this is over a period of about 4 years) so when I went back and rendered the way I normally did the problem disappeared and the 2nd time I have to say it was a fluke. Like I said computers sometimes have a wife … I mean mind of their own. :-O
    Don
