Activity Forums Apple Final Cut Pro Legacy Audio out of Sync FCP 5 on Macbookpro
  • Audio out of Sync FCP 5 on Macbookpro
    Posted by 00nate on November 14, 2006 at 5:12 pm
    Please can someone help?
    I am trying to import a DV tape shot on a sony 3ccd camera. The camera I am using to import is a sony HDV-HC1. On the Camera I hav set it to DV not HDV. I am using FCP 5 on a Macbook pro with an external firewire drive connected via a firewire hub (see below for exact spec).
    When I import video I get the error message that “the audio sample rate of one or more of your captured media files does not match the sample rate of your source tape” and that this might cause audio and video to be out of sync. On reviewing the captured file this is inded the case. The capture preset is currently set to “DV Pal 48Khz” and the device control to “Firewire Pal”.
    My question is how can I make sure the audio sample rate of the capture preset matches the sample rate of the tape? and does anyone have any ideas of how to remedy this problem.
    Any help greatly appreciated. Thanks,
    Nate
    FireWire Bus:
    Maximum Speed: Up to 400 Mb/sec
    ATA/ATAPI Device:
    Manufacturer: Formac
    Model: 0x1
    GUID: 0x72101EE000029
    Connection Speed: Up to 400 Mb/sec
    Sub-units:
    ATA/ATAPI Device Unit:
    Unit Software Version: 0x10483
    Unit Spec ID: 0x609E
    Firmware Revision: 0x38
    Product Revision Level: 08.0
    Sub-units:
    ATA/ATAPI Device SBP-LUN:
    Capacity: 149.05 GB
    Removable Media: Yes
    BSD Name: disk2
    OS9 Drivers: Yes
    S.M.A.R.T. status: Not Supported
    Capacity: 149.05 GB
    BSD Name: disk3
    OS9 Drivers: Yes
    HDR-HC1E:
    Manufacturer: Sony
    Model: 0x380135
    GUID: 0x800460104A7150F
    Maximum Speed: Up to 100 Mb/sec
    Connection Speed: Unknown
    Sub-units:
    DV-VCR Unit:
    Unit Software Version: 0x10001
    Unit Spec ID: 0xA02D
    Unknown Device:
    Manufacturer: Unknown
    Model: Unknown Device
    00nate replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
