Activity Forums Apple Final Cut Pro Legacy Audio out of sync exporting with h.264 codec from HDV timeline
  • Audio out of sync exporting with h.264 codec from HDV timeline
    Posted by Beppe Achetai on June 24, 2009 at 4:14 am
    The timeline is in HDV 1080i60.
    The rendering codec is Apple ProRes 422.
    I have exported in Apple ProRes 422 and the file works fine.
    But when I export in h.294 codec using quicktime conversion, the audio is out of sync, but not always!
    when I have some rendered clips (for example on the lower third) the audio is in sync.
    To bypass the problem I can export again a Apple ProRes 422 file, and from then a h.294, but I’m looking a shorter way to do it directly
    Any suggestions?
    John Fishback
    replied 17 years, 2 months ago
    2 Members · 1 Reply
  • John Fishback
    June 24, 2009 at 3:48 pm
    Have you performed an audio mixdown? If not, try that. Sequence Menu > Render Only > Mixdown.
    I’ve always had the best result by exporting a QT (ref or self-contained) and using that file in Compressor.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
