Activity Forums Apple Final Cut Pro Legacy Audio out of sync after compression
  • Audio out of sync after compression
    Posted by Ron Schend on May 6, 2011 at 3:58 pm
    I can’t seem to output/upload my clips to Vimeo without audio sync problems. It’s not really drifting. I can jump ahead in the clip and it doesn’t get any worse. In fact, at times it just seems like it’s skipping frames and so you don’t really see the details of the person’s mouth moving and it just seems out of sync. But it’s still quite apparent and far different from previewing the timeline in FCP.
    I’m editing the following footage:
    in a sequence with the following settings:
    I then send to Compressor with the following settings (as per Vimeo’s recommendation):
    Description:
    File Extension: mov
    Estimated size: 2.15 GB/hour of source
    Audio Encoder
    AAC, Stereo (L R), 44.100 kHz
    Video Encoder
    Format: QT
    Width: 1280
    Height: 720
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls On:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Better (Motion Adaptive)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 75
    Min. Spatial quality: 25
    Key frame interval: 24
    Temporal quality: 50
    Min. temporal quality: 25
    Average data rate: 5.12 (Mbps)
    I also tried a compressor setting with 720×480, but that doesn’t seem to make a difference.
    Is there anything obvious that i’m doing wrong here? If not, I can share a clip, but I’d rather not unless it’s absolutely necessary (this footage shouldn’t be public just yet…not sensitive, just privileged).
    Thanks.
    (Edited: said “780×420” before)
    Ron Schend replied 15 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
