Activity Forums Apple Final Cut Pro Legacy Audio out of Sync !
  • Audio out of Sync !
    Posted by Francisca Bancalari on August 19, 2009 at 12:09 am
    Hello
    i need guidance regarding out of sync audio in my captured footage.
    I used a Canon XH A1, 25F, audio recorded stereo
    I run FCP 5.1.4 in a MacPro 2GHz connected via usb to an external hard drive, never had problems with this.
    I used ‘easy setup’ settings of 1080p25 and the footage looks good except only the first clip captured is out of sync, the succeeding clips all seem to be fine. I used ‘capture now’ and also i captured using in & out points and still the same problem with the first clips of any of the tapes recorded in the same occasion.
    Am i doing anything obviously wrong? is the usb to hard drive the possible problem? otherwise…camera settings?
    I am lost!
    Thank you in advance for your time!
    F
    Margus Voll replied 17 years ago 2 Members · 1 Reply
  • Margus Voll
    August 19, 2009 at 11:47 am
    Hi.
    Have you tested to capture some black in the start so the systems get synced up by then ?
    Margus
    https://iconstudios.eu
