Activity Forums Apple Final Cut Pro Legacy Audio Ouput Question: when i go to dual mono i lose my mix
  • Audio Ouput Question: when i go to dual mono i lose my mix
    Posted by Mark Gringo on March 31, 2006 at 4:33 pm
    Hi guys, I hope someone can help me out here.
    I have mixed my FCP Sequence… all the levels are great. i now want to print to tape a unmixed version with the voice over on channel 1 and everything else on channel 2.
    so…
    1. I went into Sequence Settings > Audio Outputs> Grouping > Dual Mono
    2. I went back to my Sequence and sent the over tracks to channel 1 and the rest to channel 2.
    the only thing is… is that now all my mixed levels are peaking in the red… how do i keep the volume setting same?
    Mark Gringo replied 20 years, 5 months ago 2 Members · 2 Replies
  • Thaxter Clavemarlton
    March 31, 2006 at 8:45 pm
    Select (highlight) ALL of the audio tracks at once.
    Then choose Modify (menu) > Levels > -6 (relative) > OK.
    If -6 is not quite right “undo” that command and choose a different level setting.
  • Mark Gringo
    April 7, 2006 at 6:55 pm
    thanks!
