Activity Forums Apple Final Cut Pro Audio-only ripple edit in 10.3?
  • Audio-only ripple edit in 10.3?
    Posted by Anton Antokhin on December 8, 2016 at 8:10 am
    I select a range on an video clip, hit delete, and ripple cuts it.
    I do the same on the audio-only clip and it disables the portion that was selected.
    Is there a way to ripple-delete audio-only using the range tool? What I am trying to do is to cut out a section in the middle of the music and have the remainder collapse together.
    I know I can use the blade to make two edits, but hoping there’s a better (faster) way.
    Anton Antokhin replied 9 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    December 8, 2016 at 5:17 pm
    [Anton Antokhin] “I select a range on an video clip, hit delete, and ripple cuts it.
    Yes there is. I don’t know why this changed in 10.3, but it did.
    You have to map a kb shortcut to ‘Delete Selection Only’:
    Then select a range, hit this new kb shortcut, and it works like the old delete.
  • Anton Antokhin
    December 8, 2016 at 5:55 pm
    ???? works great, thank you!
