Activity › Forums › Panasonic Cameras › Audio only insert edit – AJ-HD1400
  • Jeremy Garchow
    June 5, 2007 at 11:44 pm
    Sorry, I should have explained better.
    It obviously won’t work in firewire (that is the bad audio I am trying to cover up).
    I am trying ti insert the audio from an analog source and I can’t get it to take, it always writes over video with whatever video input is selected in the panel. There’s no way to change the video input to ‘none’ is there?
    Anyone know a secret that allows audio insert only?
    Thanks in advance.
    Jeremy
  • Jeremy Garchow
    June 6, 2007 at 3:50 pm
    Lorem ipsum mea in dolores appetere. Alii ullum sapientem no sit, nam et salutandi neglegentur. Mea an soleat partiendo urbanitas, ut stet nihil iriure quo, id odio diam timeam mea. Ne quo hinc posse hendrerit, eirmod honestatis te nam. Verear scriptorem sea cu.
    Ne nec modus facilisi delicata, quo equidem inciderint instructior ea, in conceptam expetendis sed. Ea sed diam voluptaria. Et sed sint porro. Ei sumo tempor sadipscing per, eligendi sensibus expetendis vix ut. Ne mei volutpat molestiae persequeris, alii atomorum persequeris eu vis.
    Pri an iusto viderer abhorreant. Diam dictas disputando no cum, ne pri vivendo principes. Vocent equidem alienum duo et, mea no movet torquatos. Cum habeo oportere repudiare ei, per an vivendum recusabo indoctum.
    Anyone want to hop on this train with me? On site, trying to figure this one out.
    FCP 5.1.4 OSX.4.9 QT7.1.6 MacBookPro with crackly firewire audio that needs to be relayed.
    Jeremy
  • Jeremy Garchow
    July 3, 2007 at 3:22 am
