Activity Forums Apple Final Cut Pro Legacy Audio on Tracks 3 & 4 Beep
  • Audio on Tracks 3 & 4 Beep
    Posted by Rene Spencer on June 7, 2009 at 8:58 pm
    I’m working with HDV 1080i (1440×1080) with 48kHz audio.
    For the first time ever my timeline will not allow me to lay more than 2 audio tracks down in the same timecode… I can put audio on Tracks 1 and 2 OR Tracks 3 and 4 — but not 1 and 2 and 3 and 4.
    I can’t do any overlapping of audio.
    I’ve checked my audio rates and all the clips are the same as my Sequence — 48kHz
    When I put in any overlapping audio I get “beep beeps” on playback for the audio on Tracks 3 and 4 plus, the red render bar appears… when I render, absolutely nothing happens.
    I’m sure there’s a setting somewhere that I’ve overlooked but I’ve spent a lot of time checking everything and searching your forum (and others) for a clue. Nothing so far.
    Any help will be met with great enthusiasm and appreciation.
    Rene Spencer replied 17 years, 3 months ago 2 Members · 3 Replies
  • Rene Spencer
    June 7, 2009 at 11:35 pm
    Never mind… for some reason, it’s now working… after 4 days of not working… Mercury in Retrograde?
    Maybe the witch doctor I hired actually was worth the coin.
  • Ben Holmes
    June 8, 2009 at 11:47 pm
    There is a setting in the user preferences that specifies the maximum number of ‘real time’ (ie. no beeps) audio tracks. I would recommend you set this to no more than 6/8, and render out the audio where multiple tracks are used.
    Have a nice day.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Rene Spencer
    June 9, 2009 at 12:09 am
    Aha! That did it… timeline is “back to normal” and playing nicely with the audio and overlaps.
    Many kind thanks. I feel a bit foolish for not discovering this myself however, I won’t ever forget it now.
    Again, thank you.
