Activity Forums Apple Final Cut Pro Legacy Audio Not Working in FCPHD
  • Audio Not Working in FCPHD
    Posted by Clownman83 on June 9, 2006 at 11:22 pm
    I just recently captured some footage and the audio tracks show nothing at all on them. When I open the files in Quicktime, the video and audio both work. When I drag the files to my timeline there is absolutely no audio levels. The audio format is in Mono Mix. Is this my problem? If so, is there a way to convert the files? Please help, this is for a school project that needs to be turned in soon!
    Debe replied 20 years, 2 months ago 3 Members · 3 Replies
  • Kevin Monahan
    June 9, 2006 at 11:57 pm
    Do you have waveforms? Look in the Audio Tab when you load a clip into the Viewer.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Clownman83
    June 10, 2006 at 5:43 pm
    There are no waveforms at all! I captured the footage on a different computer and imported them onto mine. I put the files in the timeline and viewer in final cut on the other computer but for some strange reason when I do the same on my computer, there is absolutely no audio. But there is when I play the clips in quicktime. I think the versions of final cut are pretty close between computers, would this have an effect? Otherwise do you know of any programs that will record “system” audio if I were to play the audio out of quicktime and sink up the files?
  • Debe
    June 10, 2006 at 6:24 pm
    Any possibility these files are muxed?
    Files that play back in QT but FCP doesn’t see the audio usually need to be demuxed.
    Google MPEG Streamclip.
    debe
