Activity Forums Adobe After Effects Audio not working in after affect effect CC
  • Hector Vera
    July 8, 2024 at 3:24 pm
    Try these following steps to see if this will help and best of luck:
    1. In Adobe After Effects, go to “Edit” menu > “Preferences” > “Audio Hardware”.
    2. Under “Device Class”, find and select the device that corresponds to your audio hardware (likely a USB audio interface or a sound card installed in your computer).
    3. If the “Digital Out to Optical (S/PDIF)” option is checked, uncheck it. If it is already unchecked, skip this step.
    4. Click “OK” to close the preferences window.
    After you have done these steps, try again to preview your comp and see if the audio is able to play correctly. Let me know if it helped or have any further questions.
