Activity › Forums › Apple Final Cut Pro › Audio not playing through audio interface
  • Audio not playing through audio interface
    Posted by Dallas Kruse on April 15, 2022 at 8:21 pm
    I’m having an odd issue.
    I’m on FCPX 10.6. Big Sur.
    I use an Antelope Orion 32+ as my audio interface. Never had an issue with it till trying to use it with FCPX.
    FCPX will not play audio through my Orion interface. No matter what I do…it will not route through my interface. My System Preferences have the Output selected to run through the Orion and all Mac audio runs through it fine.
    If I switch to “external headphones”, then FCPX will pass the audio through the headphone port … but it’s 100% distorted (that’s another issue in it of itself).
    Interestingly enough, if I restart the computer, immediately open FCPX and start playback, it will play for a few seconds through the interface but then will stop. It’s as if somehow it’s recognizing there’s external audio hardware and then ceases to pass through.
    I never had this issue when I was using MOTU (firewire) hardware. But now, with this new interface (it’s been a year or so since I’ve used FCPX), FCPX doesn’t seem to want to play nice.
    Any suggestions?
    John Fishback replied 4 years, 5 months ago 2 Members · 1 Reply
  • John Fishback
    April 15, 2022 at 8:45 pm
    It’s been a long time since I set this up when I had a similar issue. I think you need to use the Audio MIDI Setup app in the Utilities folder in the Applications folder. Open the app and look for your interface. Define the input & output. Also, you need to configure the speakers. There’s a button for that. Sorry I can’t be more specific. Hopefully this helps.
