Activity › Forums › Apple Final Cut Pro Legacy › Audio not playing back
  • Audio not playing back
    Posted by Pat Defilippo on May 3, 2006 at 2:33 am
    Hello again, all!
    I have been noticing that my audio will, from time to time, not play back through the AJA Io LA and mixer. I’ll “refresh”, and it still won’t work. I’ll double-check all of my timeline and playback settings and even re-start FCP, but it won’t help. I can see the meter working in FCP, but nothing is coming out. ProIO is selected for audio playback and the pots on the audio mixer are up and on.
    Then, I’ll go to “Edit to Tape” and drag the very same Sequence – and it will work! I’m sure I’m doing something wrong because I’ve only had this system for four months, but I’m not sure what that is. Does anyone have any ideas?
    Thanks very much,
    -Pat
    G5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
    30″ Cinema Display & 17″ Sony SVGA ~
    Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
    AJA Io LA ~
    Final Cut Studio ~
    Sony UVW-1800 Beta-SP ~~~
    P D Post Productions, Inc. ~
    TV~DVD~VHS~CD~WEB
    for Corporate Communications, Commercials, Infomercials, Television Programs, Family Occasions since 1983 ~
    E-mail PD@PDPost.com ~
    Website http://www.PDPost.com ~
    Business/Cell Phone (847) 275-5671
    Jerry Hofmann replied 20 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 4, 2006 at 12:46 am
    Triple check those settings, and if they are right, then trash your preference file for FCP.
    Also be sure of your cable setup. You are routing this thru a mixer and then on to powered speakers or an amp? or is the deck in between? if so make sure it’s set to E/E…
    Jerry
