Activity › Forums › Apple Final Cut Pro Legacy › Audio Not Loud Enough
Posted by Rp on July 6, 2007 at 2:58 amMy audio is a bit low and I have boosted in in the audio mixer as loud as it will go. Is there another way to make it louder?
David Bogie replied 19 years, 2 months ago 5 Members · 6 Replies -
Neil Ryan
July 6, 2007 at 6:26 amYou can get more ‘lift’ within Soundtrack Pro.
You can also ‘normalize’ the audio.I don’t know how well you know the app but it is almost certainly your answer. Interacts with FCP.
cheers.
Neil Ryan
Post Production
The Pod Multimedia
http://www.the-pod.com.au
13
July 6, 2007 at 6:50 amAnother possible solution is to copy your audio and past it in another audio track & lining them up together.
Peter Wolsey
July 6, 2007 at 12:57 pmIt’s a common problem here too, with the sources tapes have the audio recorded at too low a level. Try using the excellent Compressor/Limiter provided in FCP in your Audio Filters. It gets us out of trouble many a time. Make sure you tick the ‘Preserve Volume’ box and set the compression to around 1.5 which will squash the audio dynamics a bit but at the prize of giving you much more volume to play with. You need to experiment with the ‘Threshold’ value to make it operate successfully.
I often find this better and quicker than firing up Soundtrack Pro (which is nonetheless a very good tool).
Good luck, Pete -
David Bogie
July 9, 2007 at 1:37 pm> Another possible solution is to copy your audio and past it in another audio track & lining them up together. < Yar, used to use that till I discovered Dynamics Processor under AU audio filters. Far more interesting and useful. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
