Activity Forums Adobe After Effects audio not coming in vidoe files
  • audio not coming in vidoe files
    Posted by Robert William on August 10, 2008 at 9:18 pm
    hi,i have video.i want to edit in adobe after effects but the audio wont come on.anybody know how to play the audio?
    Brian Lynn replied 18 years ago 3 Members · 2 Replies
  • Laurie Turner
    August 11, 2008 at 8:47 pm
    This site will tell you all you need to know to get started.
    https://www.videocopilot.net/blog/?p=131
  • Brian Lynn
    August 12, 2008 at 12:13 am
    If you are using the Space Bar to start a preview you wont get audio… if you hold Alt or Control (I forget which) and scrub the timeline you should be able to hear audio, and if you use the zero key on the 10-key pad to start a RAM preview you should get audio also.
    If the clip plays with audio in QuickTime/MediaPlayer/VLC then it really should have audio after importing into After Effects.
    Also if the clip does have audio then you should see the audio properties in the Project tab when you select it.
    Brian Lynn
