Activity Forums Adobe After Effects Audio not being output to Quicktime
  • Audio not being output to Quicktime
    Posted by Shawn Marshall on July 16, 2013 at 7:04 pm
    For no apparent reason After Effects CS6 (11.0.2.11) will no longer output audio to a Quicktime unless I explicitly go into the Output Module and uncheck and then recheck the Audio Output box.
    I have a bunch of Output Modules set up with various codecs, all with the default audio enabled. If I set up a render, select one of those Output Modules, and render, the resulting Quicktime will not have any audio encoded. No audio track is created at all, just video (no little VU bars in the lower right corner of Quicktime Player Pro.)
    I’m on a Mac Pro running OS 10.7.4, Quicktime 7.6.6.
    Do I need to delete some preferences?
    Thanks.
    Shawn Marshall
    Marshall Arts Motion Graphics
    Cassius Marques replied 13 years, 2 months ago 2 Members · 1 Reply
  • Cassius Marques
    July 18, 2013 at 6:15 pm
    Did you imported that module from a prior version of AE by any chance? Sometimes they go crazy when you do that, I tend to allways remake them instead of importing.
