Activity › Forums › Adobe Premiere Pro › Audio noise, Hiss..
Audio noise, Hiss..
Posted by South Video on October 7, 2006 at 5:40 pmHaving some problems wirh hiss and noise on my audio one track,
tried denoiser EQ, and the rest of the toys, any suggestions? what about a audio software like audition, 1.5 or 2.0 or something else?
Thanks!Mark
South Video replied 19 years, 11 months ago 2 Members · 5 Replies -
Blast1
October 7, 2006 at 6:31 pmAudition has better noise reduction tools, have you tried to use the parameteric equalizer in premieres audio effects to reduce specific frequencies bands, low and high pass filters?
South Video
October 7, 2006 at 10:14 pmHi Blast, Yes, the Parameteric EQ helped alot!
Think part of my problem might be I went with the automatic audio level gain, it brought up my DB’s in the double digits, will try to bring them back to 0.0 DB then bring them up manually in the single digit range.
Was using Premiere 6.5 before and was use a % audio gain control, what is 100% gain in +DB’s on 2.0?
Thanks!Mark
South Video
October 8, 2006 at 8:30 pmHi Blast, Thank you for the info, will adjust audio tomorrow and let you know!
Mark
South Video
October 9, 2006 at 9:09 pmHi Blast, Looks like that suto audio gain was the problem, brought everything down to single db digits and my hiss is now very low, and with the help of the denoiser am back where it should be.
Thanks again for all your input!Mark
