Activity › Forums › Apple Final Cut Pro Legacy › Audio no Video in FCP 6
  • Audio no Video in FCP 6
    Posted by Lynn Albertson on April 10, 2010 at 7:43 pm
    I’m pretty new to using HD footage in Final Cut Pro. I’m using XDCAM footage so I imported the clips into XDCAM Transfer, made them quicktime files, opened final cut pro, and set the setting to XDCAM easy setup (24p). When I play the videos I can only hear the audio and not see the video, the screen is white. FCP also won’t let me render clips. Any advice?
    Don Greening replied 16 years, 5 months ago 3 Members · 2 Replies
  • Michael Gissing
    April 10, 2010 at 11:16 pm
    Do you have the latest version of FCP 6? If not then update and see if that fixes the problem. White screen probably means you don’t have the XDCam codec installed. A lot happened in version 6 with XDCam so you might just have a version too early
  • Don Greening
    April 11, 2010 at 6:15 am
    There are 2 different kinds of XDCAM codecs in FCP:
    • XDCAM HD
    • XDCAM EX
    XDCAM EX codecs are more recent than XDCAM HD. To edit XDCAM EX in FCP you need the following minimum requirements:
    • FCP 6.0.2
    • Quicktime 7.3.1
    • Mac OS 10.4.11
    – Don
