Activity Forums Blackmagic Design Audio monitoring problem
  • Audio monitoring problem
    Posted by Savamon on January 24, 2006 at 9:14 am
    Hi all,
    My client is experiencing a problem with monitoring sound via S/PDIF while capturing with his Decklink Extreme card. Even though the preview is selected in the clip setting tab of the log and capture window there is no sound coming through. I played around with different sound settings in System Preferences, but no luck. I only managed to monitor sound while capturing through digital out on his G5. Playback works fine.
    Trashing the preferences didn’t work
    Has anyone else experienced this ?
    Kristian Lam replied 20 years, 7 months ago 3 Members · 3 Replies
  • David Roth weiss
    January 24, 2006 at 7:16 pm
    Has he checked the preview box in the FCP capture panel?
  • Savamon
    January 24, 2006 at 9:35 pm
    Yes, the box it checked
  • Kristian Lam
    January 25, 2006 at 12:32 am
    Is Black Video Output enabled in the DeckLink preference pane? If so, disable it and see if there’s a difference.
    regards
    Kristian
    Blackmagic Design
