Activity › Forums › Sony Cameras › Audio monitoring one channel only
  • Audio monitoring one channel only
    Posted by Robin Probyn on October 3, 2009 at 1:09 am
    Hi
    Is it possible to monitor say only ch1 from the minplug audio out .. couldnt find a switch on the body,or anything in the menu???
    Robin Probyn replied 16 years, 11 months ago 2 Members · 6 Replies
  • Rafael Amador
    October 3, 2009 at 2:12 am
    Look in the menu.
    rafael
    http://www.nagavideo.com
  • Robin Probyn
    October 3, 2009 at 2:16 am
    Errr thanks,but as I say I did and couldnt find anything about it.. any more details as where in the menu..
  • Rafael Amador
    October 3, 2009 at 4:04 am
    Menu Audio Set> Audio Output> Monitor CH.
    rafael
  • Robin Probyn
    October 3, 2009 at 4:07 am
    ah! many thanks.. I did see that but thought it was just for playback? that will also work for real time monitoring from the mini jack plug..?
    thanks again for your time
  • Rafael Amador
    October 3, 2009 at 4:29 am
    [Robin Probyn] ” that will also work for real time monitoring from the mini jack plug..? “
    Right.
    A pleasure to help.
    Cheers,
    rafael
  • Robin Probyn
    October 3, 2009 at 4:34 am
    You are both a learned scholar and a gent..
