Activity Forums Apple Final Cut Pro Legacy audio monitoring during capture with HDV
  • audio monitoring during capture with HDV
    Posted by La Mer walker on April 20, 2006 at 2:36 am
    I am currently stumped by what should be quite simple. I am not getting any monitoring audio while attempting to log tape. The audio meter is moving to show the audio is there, but I can’t hear it while logging. The book says to check the audio monitoring box under the appropriate tab. I found the box with no problem but it is uncheckable. For whatever reason FCP will not let me check it off.
    I get audio fine while viewing other clips that have already been imported just not real time audio while viewing straight from the camera.
    any help with this would be great!
    Matthew Small replied 20 years, 4 months ago 2 Members · 1 Reply
  • Matthew Small
    April 20, 2006 at 4:25 am
    When you have the log & capture window open, the second tab where you can check video and audio, there’s a preview check box in v5 that should allow you to pass the audio through to your speakers.
    Matt Small
    Pair of Hands
    Sherman Oaks, CA
    “If it was easy, everyone would do it.”
