Activity Forums AJA Video Systems Audio Monitor output
  • Mark Tyson
    February 24, 2006 at 3:15 am
    Thanks fellows…found the info I need online.
    Mark Tyson
  • Bob Zelin
    February 24, 2006 at 10:43 pm
    Mark –
    when you did your first 1″ room, you had an audio mixer in it. I bet you had a Sony MXP-290, or a Soundcraft 200B. These very same mixers will work great with your FCP system (of course, a nice little Mackie or Behringer will do just fine as well).
    bob Zelin
  • Mark Tyson
    February 24, 2006 at 11:28 pm
    Bob;
    ya…you’re probaly right…just trying to beat the clutter! Thanks
    M. Tyson
  • Tom Matthies
    February 28, 2006 at 2:57 pm
    Hi Mark.
    How are things in the “Springs” these days? I sure miss the weather out there.
    Anyhow, you have most likely found that the outputs from the 25-pin D connector are “live” all the time along with the XLR connectors. I believe that they are line level, but not sure if they are 0db or +4db. I run my Io out to a Beringer mixer and use it for a small audio DA. It works well since it has a couple of +4db outputs to feed the Beta decks , a control room output for the audio amps and an unbalanced -10db to feed a small RCA-type da that in turn feeds the VHS machines and the DVD recorder. I have also toyed with the idea of making use of the additional outputs at the D-connector. What did you find out about the levels from the website? I’m interested as well. I too have a tray of vintage DAs that really should be retired.
    Say “Hi” to the old gang…or to whoever is still there.
    Tom
Page 2 of 2
