Activity Forums Apple Final Cut Pro Legacy Audio Mixing a Sequence
  • Audio Mixing a Sequence
    Posted by James Coppens on June 29, 2010 at 10:36 pm
    I have a sequence that is a collection of clips. I am doing a voice over but I want to lower the sound of the sequence during my voice over. I’ve been doing this by manually lowering the decibel level of each clip in my sequence, is there a way to lower the level of a highlighted area without affecting the master level so the voice over decibel level isn’t affected?
    Many Thanks
    https://www.jimmycoppens.com
    Illya Laney replied 15 years, 10 months ago 3 Members · 4 Replies
  • Dan Charrington
    June 29, 2010 at 10:49 pm
    Select all the clips you want to adjusts and choose Modify>>Levels (or Command+Option+L)
    You can adjust the Gain in the slider that appears. The two choices (Relative/Absolute) mean the following:
    Relative: adjusts all clips relative to what they are currently set at. ie – a clip at 10db will go to 4db if you enter “-6”
    Absolute: sets all clips to whatever level you enter. ie – a clip at 10db will go to -6db if you enter “-6”
    Hope that helps.
    Dan Charrington
    Supervisor, Non-Linear Technologies
    MIJO
    635 Queen St E. Toronto, ON
    416-964-7539
    MacPro 8-core Xeon 2.8GHz, 10gb Ram, AJA Kona 3 SD/HD
  • Illya Laney
    June 29, 2010 at 10:51 pm
    Highlight all the clips you want to adjust then hit control + or – to raise and lower dB. It helps to have keyframe overlays turned on so you can keep track of the relative volume levels.
    Motion Design, Color, Editing
    SWGC Incorporated
  • James Coppens
    June 29, 2010 at 11:33 pm
    You are the man! Can I facebook friend you? I’ve been struggling with that one for a week or so!!
  • Illya Laney
    June 30, 2010 at 5:05 am
    Haha. No problem.
    SWGC Incorporated
