Activity Forums Apple Final Cut Pro Legacy Audio Mixing
  • Posted by Canadianguy on August 26, 2006 at 12:22 am
    When I raise the volume using the master fader, will that actually raise the level when I output say to DVD? I’ve already raised the individual audio track volume the max 12 db, but it is still too low, so I guess the master volume is my last resort. Thanks
    Tom Meegan replied 20 years, 1 month ago 2 Members · 1 Reply
  • Tom Meegan
    August 26, 2006 at 11:03 am
    I would avoid the master in this situation as it will boost the gain of all the clips in the timeline.
    Either nest the offending clip and then adjust the gain on the nest, or apply an audio filter with a gain control and adjust the filter to give the clip more level.
    Tom
