Activity › Forums › Adobe Premiere Pro › Audio MIxer wont change levels on just one clip
Posted by Dale Roberts on May 8, 2013 at 4:35 amHi,
I am trialling Premiere and having an issue that I can seem to find a solution to online. In my sequence, when I use the fader in the mixing panel to change the levels of one clip in a sequence its doing it for EVERY clip in my sequence which is causing me lots of headaches… What am I doing wrong?
Many thanks
daleGiovanni Novaro replied 9 years, 6 months ago 5 Members · 8 Replies -
Victor Perez
May 8, 2013 at 7:55 pmFor now, changing audio in the audio mixer adjusts all clips on that track. This will change when Premiere Pro CC is released. To change audio on a clip by clip basis you need to select the clip and change the levels in the sequence. This Andrew Devis tutorial will explain it better.
https://library.creativecow.net/articles/devis_andrew/Premiere-Pro-CS6-Basics_78/video-tutorial
Hope that helps
Victor
editvictor.com
http://www.hbhm.tv
http://www.itvisus.com -
Dale Roberts
May 8, 2013 at 9:40 pmHI thanks for the this…
What I mean is it is happening in the actual sequence… WOrking in the sequence I change the level of one clip and it changes the levels of all clips in the sequence that i am working on… ill watch the tutorial soon tho… thanks!
dale
Victor Perez
May 9, 2013 at 9:54 pmIs it possible the sequence has “Show Track Keyframes/Volume” instead of “Show Clip Keyframes”
Having Track Keyframes/Volume selected will cause the entire tracks audio to change when adjusting the volume IN the Sequence.Victor
editvictor.com
http://www.hbhm.tv
Dale Roberts
May 9, 2013 at 11:28 pmThanks for this but sadly no… Its a mystery.. its set as you said from the outset…
Ill have a look at the link soon and see if that helps… very strange… maybe its because im in trial mode?
dale
Ann Bens
May 12, 2013 at 8:54 amWhen you use the Audio Mixer it affects the whole track, if you want just one clip to fade the audio you do that in the timeline with keyframes or use audio cross dissolves to fade in and out.
In the audio track header you set it to Show Clip Keyframes.
You can use the Pentool to set keyframes or hold down ctrl and use the Selection Tool.———————————————–
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Kevin Lee
December 23, 2013 at 11:46 pm -
Giovanni Novaro
March 4, 2017 at 3:35 amHey I’m having the exact opposite problem – audio mixer will ONLY affect one clip. It’s driving me crazy, I need to do quick track-level adjustments. Premiere CC 2017 – any advice? I’m sure it’s a quick fix but for the life of me I can’t find the damn option.
Giovanni Novaro
March 4, 2017 at 3:38 amNevermind, I got it! Did not realize Adobe included a new ‘Audio Clip Mixer’ menu in the CC release – the entire time I thought I was inside the ‘Audio Track Mixer’. I feel dumb.
