Activity Forums Apple Final Cut Pro Legacy Audio mixer and ProRes: Dropped frames
  • Audio mixer and ProRes: Dropped frames
    Posted by Matt Larson on December 8, 2008 at 6:44 pm
    I typically use the audio mixer to make adjustments to the audio levels in my timeline on-the-fly. When I edit a 720p59.94 Pro Res sequence and do this, typically several seconds later I will get a Dropped Frames message. If I don’t touch the mixer during playback, I have no problems playing the timeline back.
    This sequence consists of one video track and one audio track with several Pro Res (not HQ) clips (all captured through FCP using the AJA KONA 3 Pro Res Easy setup. Looks like my storage is plenty fast watching the Activity Monitor window.
    Seems like the FCP should be a little more robust than this. Any suggestions (other than stop the playhead before adjusting my audio!)
    Here are the details:
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
    Matt Larson replied 15 years, 11 months ago 7 Members · 19 Replies
  • 19 Replies
  • Bob Zelin
    December 8, 2008 at 7:09 pm
    No offense but –
    you are thinking in terms of “magic and voodoo” if you think that changing your audio mixer is causing a dropped frame error. It’s not. I don’t care what you have observed.
    Although I am not a big G-Tech fan, you have a VERY FAST disk drive array. I advise you to go to the AJA Utilities folder and run AJA System Test on your G-Speed XL 12 bay array. It’s probably insanely fast – certainly faster than the 18Mb/sec required to do 720p 59.94 Pro Res that you are trying to do. But certainly RUN AJA SYSTEM TEST right now (choose 1920×1080 with a 2 Gig file – this will tell you what your drive speed it – it’s probably hundreds of Mb/sec).
    So, if your drive array is not defective (and you will tell by running AJA System Test), either your sequence is corrupt, or you have the worst static electricity problem in the world. I dont’ care if you you peak out your audio to severe distortion – it’s not going to affect your dropped frame issue.
    I urge you to play back individual clips – move your mixer – any dropped frame errors – probably not. Now, CREATE A NEW SEQUENCE, and randomly drag in your clips into this NEW sequence. I bet it plays back when you move your mixer. If it does not, you in fact may have a severe static electricity problem (but highly doubtful).
    What kind of mixer are you using ?
    Bob Zelin
  • Alan Okey
    December 8, 2008 at 7:22 pm
    [Bob Zelin] “What kind of mixer are you using ? “
    Bob,
    I think he’s talking about the software mixer panel tool in FCP. It’s conceivable that his G5 doesn’t have enough CPU grunt to simultaneously decode ProRes and perform real-time audio mixing during playback. In other words, it might be a question of CPU capacity rather than disk badwidth. After all, the G5 isn’t supposed to be fast enough to encode ProRes during live video capture, so it might be related…
  • Alan Okey
    December 8, 2008 at 7:24 pm
    D’OH! I just reread the OP’s post and he is indeed using a Mac Pro, not a G5. So much for that theory…
  • Matt Larson
    December 8, 2008 at 7:40 pm
    Bob, as the poster below correctly guessed it is FCP’s audio mixer that seems to cause the dropped frames. You may be right about the static electricity problem though: Now that’s it’s winter here in Wisconsin I get a wicked shock every time I touch my Mac Book Pro. I suspect you are right however, that is not causing my Mac Pro to drop frames!
    I actually have had this problem for a while. I did an erase and install when upgrading to Leopard a few months ago but that had no effect on this playback glitch.
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    G-Speed XL 12 RAID
  • Matt Larson
    December 8, 2008 at 7:43 pm
    And yes the G-Tech drives are very fast. READ speeds in the 300MB range and writes faster than that. I have been happy with the drives (had them for just over a year) and their support staff is almost AJA-like!
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    G-Speed XL 12 RAID
  • Todd Dalton
    December 8, 2008 at 9:39 pm
    Hi!
    I’m running a similar system (in fact my Sonnet raid’s prob not as fast). ‘Fraid to say that I’ve never experienced dropped frames with either an external usb mixer or dragging the software sliders. How many realtime tracks are you generally trying to do? I don’t use over 8 (more of a legacy of my editing experience than anything)….
    Or keep trashing your settings? 🙂
    Todd.
  • Gary Adcock
    December 9, 2008 at 4:46 pm
    [Matt Larson] “2 x3Ghz Quad MacPro 9 GB RAM “
    FIrst of this sounds as if there is something causing the CPU flush memory.
    second- this RAM config sounds fishy – I am guess 4-2G sticks and 2-512’s
    I have found randomized annoying issues with oddball RAM configs – try pulling the smallest pair.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Tom Daigon
    May 16, 2009 at 7:16 am
    Im having the same exact problems with no mismatched memory and the same CPU and AJA setup. Any follow up?
  • Tom Daigon
    May 17, 2009 at 3:14 am
    Update: There seems to be an indication that the latest release of FX Factory broke the audio mixer tool in FCP. Several folks have reported deleting FXF and the mixer functions again. It has been reported to Noise Industries.
  • Matt Larson
    May 19, 2009 at 2:53 pm
    Did they release a new version that fixes it? I haven’t had a chance to check this out, but I hope you are right about the fix.
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    G-Speed XL 12 RAID
